I have been pondering how accurately the center ring must be placed in order to accurately collimate using lasers and barlowed lasers.
Most often I seem to get very good results with my normal technique, an computer drawn circle with a center hole, cut out, center dot is then placed and the ring is place around the hole. Nice star tests in F/5 scopes.
However with the realization that the diffraction limited circle of an F4 scope is only 1.1mm, I am wondering if this means that dot needs to place with a high degree of accuracy, maybe 0.1 mm or even less??
I know one can collimate using a star test, probably the best way to go for sure, but I am doing this alone and moving from the eyepiece to the cell, finding the star, well it ain't all that easy.
Any thoughts, experiences, analysis would be appreciated.
Clear skies
jon
Clear skies
jon
