Philip Imbrogno
Elephant Trunk Nebula
Center spotting the mirror
Started by progenitor, 02/12/2006 11:35PM
Posted 02/12/2006 11:35PM Opening Post
I have 24h before shipping out my new reflector to WSP and found that the mirror is not marked. There is a center ca. 2 inch protective film for the "foot" of the mirror cover but no center cutout in the film nor a marked spot. A web instruction would ne nice.
David
Posted 02/13/2006 01:24AM #1
Best think I can give is a way of doing it.
Place the mirror on a sheet of paper and use a pencil to mark around it. Then cut out the circle. Fold the circle in half. then in half again. Now it looks like a piece of pie. Cut off the very tip of the point, just a little bit.
Open up the circle and you will have a hole in the center. Place the paper over the mirror with the edges matching the mirror perfectly and carefully use a marker pen to make a spot through the hole in the paper by gently pressing the tip of the pen on the hole.
Then apply a paper reinforcer or what ever you prefer. You can just use the spot too as it will show well when a laser hits it or can be seen with a Cheshire or other tool.
Posted 02/14/2006 03:49AM #2
David
David,
You've probably done it by now, but here is how I center "dot" my mirrors....
I make a plexiglass disk exactly the same o.d. as the mirror. I use a homemade router table to turn the disk, and can get it very accurate. Because I use a pivot to it, the disk winds up with a 1/4" hole in the center.
I put a 1/4" drill bit just through the hole, push a fiber washer onto the protruding bit, put a little rubber cement on the washer side away from the disk, and then carefully center the disk on the mirror. A little downward pressure on the center of the disk will push the washer against the mirror. While still pressing the disk downward, I pull the drill bit out. Releasing the pressure leaves the washer nicely centered on the mirror.
I also use the disk when I send the mirror out for coating, or if I store the mirror for a while. I lay it on top of the mirror and put a few pieces of tape around the edge.
Clear skies, Alan
