Ghost of Cassiopeia
Collimation of SCT with f6.3 reducer
Started by heliophile, 01/27/2007 01:04AM
Posted 01/27/2007 01:04AM Opening Post
Hello:
I have a C5 that has become my primary grab and go scope for backyard viewing in my light polluted part of the world. I collimated the scope and have good diffraction rings on both sides of the focus. However, once I put a f6.3 reducer in place, the diffraction rings are good on one side of the focus but a bit off on the other. I am not experienced enough to know if this is on the near or far side.
I was wondering if this is an expected situation with the reducer in place, and whether it is affecting my resolution. Frankly, the seeing has been so bad lately it is hard to tell if the reducer is downgrading the view.
Has anyone noticed ill effects in resolution from using a reducer? Is it possible this situation is caused by poor performance of the production sample that I have?
Thanks
Rey
Posted 01/28/2007 05:47PM #1
Hello Tom and Ed:
Thanks for your responses. By the way, I do have Bob's Knobs installed on all my SCT's. I would not try to collimate without them.
Ed, to answer your question. My comment about the diffraction rings is that with the reducer in place they are concentric on one side of focus but not the other. I have rescrewed the reducer into the visual back a couple of times to see if it made a difference. In any case, if the reducer was set off axis, I would expect that it would create off center concentric rings on both sides of the focus.
As you mentioned, I put the reducer in place for wider field views, generally at low power, where the ill effects of poor collimation would matter the least. I wanted to leave the reducer in place for high mag views more out of convenience than anything else, but don't mind having to remove it if it turns out that affects performance.
I am looking forward to a good night of seeing to see if I can see a difference in resolution on Saturn at comparable magnifications with and without the reducer.
Clear Skies
Rey
