VDB 142 Elephant Trunk HOO
Comet Catcher Focuser Upgrade
Started by mielejr, 11/08/2006 03:01PM
Posted 11/08/2006 03:01PM Opening Post
Hi,
I picked up a used comet catcher (the 5.5" orange tube model) and I really like the wide field views. However, I don't like the focuser very much. I was thinking about locking down the moving focus plate and removing the threaded on eyepiece tube. Then installing a flat based rack and pinion style focuser right over the hole. I would lock the focus plate down in the center of its travel range and try to find a focuser that had about the same height as the eyepiece tube that came with the scope. Has anyone tried a mod like this? Any comments or thoughts on how well it might work. Thanks.
John
Posted 11/08/2006 03:47PM #1
I have not tried this yet, but I was wondering if the
female 1.25" tube on the stock focuser could be replaced
with one of these Borg helical focusers. Would be a very
nice elegant solution, if it works. If you got lucky with
the threads, it might just screw into the Comet Catcher
stock focuser plate and be as simple as that. I think I will
look into it some more.
http://www.sciencecenter.net/hutech/borg/parts/html/4317.htm
http://www.sciencecenter.net/hutech/borg/parts/html/7315.htm
Posted 11/08/2006 05:25PM #2
I do not believe you would have enough back focus for most eyepieces. Moving the primary - or secondary as in the CC case - drastically moves the center of the FL. It is why the SCT's can focus just about anything.
Why is it you don't like the sliding focuser? IMO it is a design that has some merit - and wish more ATM'ers would experement with....
Posted 12/05/2006 07:35AM #3
I used the rotating Borg helical to upgrade my LOMO Astele 102MN for planetary viewing. I used the 1.25" Borg nosepiece and dropped the focuser into the 102MN R&P focuser. To offset the 1.5" helical focuser optical path length, I use a Siebert SCT 4 or 1.8X MaxLite binoviewer OCA screwed into the end of the helical nosepiece and it makes it about parfocal with an eyepiece used alone. I prefer this setup to a 2.5X TV Powermate because it adds fine focusing for planetary viewing and costs about the same and is shorter. The 1.8X MaxLite has threads for filters but the Powermate does not. The 1.8X MaxLite is a telecentric magnifier like the Powermate, but much smaller and lighter. You can screw it into a 1.25" extension tube and use it just like a Powermate, plus it screws onto the nosepiece of binoviewers and is fully inserted into a Dob focuser. A bit more versatile than the Powermate. I can also use it on the nonrotating 1.25" Borg helical focuser which can be screwed into a T-threaded Baader diagonal or MaxBright binoviewer or other female T-threaded accessory.
