Jay Messeroff
Lunar & Solar Transits
Cutting my reflectors tube?
Started by dhahn365, 06/02/2008 06:44PM
Posted 06/02/2008 06:44PM Opening Post
I currently have an Orion XT8 on a dob mount, but I decided to take the tube off and put it on my CG-5 mount. I realized that balancing the tube caused the eyepiece to be quite high off the ground and difficult to reach with my eye. So, I thought that it would probably help if I trimmed off 200mm of the tube to shorten it up. Does anyone have any ideas on the best method or if I should even attempt this?
David Hahn
Posted 06/02/2008 10:12PM #1
David
I don't think you can shorten the tube. The scope has a fixed focal length so unless you move the spider down AND install a huge secondary AND install a very tall focuser you are stuck with the current configuration. Two things you can try is to lighten the lower end and/or add some weight to the top end. This will shift the balance more towards the middle. However this may overload the mount. What is the problem with the dob configuration?
Buck
