My brand-new 10" f/5 Sky-Watcher Collapsible Dob saw first light from my front yard on Wednesday night. I purchased the Sky-Watcher in order to have an easy-to-transport, moderately large aperture that I could use in conjunction with my 101mm Tele Vue refractor while observing from local dark sites. Despite the less-than-excellent transparency and seeing, local light pollution, limited horizons, and bright moonlight (and having to rely on a right-angle 50mm finder scope), I was able to locate and observe a number of celestial objects, including Jupiter, the Moon, Albireo, Eta Cassiopeiae, Gamma Andromedae, Gamma Arietis, M15, M31, M34, M39, M45, M103, NGC 457, the Double Cluster, and Stock 2.
I used a 35mm Tele Vue Panoptic, the 25mm (the eyepiece was labeled 26mm) Plössl supplied with the scope, a 19mm Tele Vue Panoptic, a 13mm Tele Vue Ethos, the 10mm Plössl supplied with the scope, an 8.8mm Meade UWA, a 5mm Tele Vue Nagler T6, a 4mm BO/TMB Planetary, and a 2.5x Powermate. Images were about what one would expect from a fast 10" Newtonian, given the conditions.
Collimation was a bit off out of the box. I tweaked it somewhat using a laser collimator but due to the high profile focuser I couldn't see exactly where the return beam was hitting. Mechanically, the scope worked quite well. Movements in altitude and azimuth were fairly smooth and the altitude lock was able to handle the weight of my 35mm Panoptic when viewing close to the horizon. I didn't much care for the adapter necessary for bringing 2" eyepieces to focus but I can learn to live with it.
All in all, the 10" f/5 Sky-Watcher Collapsible Dob is quite a bargain at its current sale price of $495.
Dave Mitsky
Dave Mitsky
