Glued secondary ?
Started by matt elliott, 02/04/2010 01:10AM
Posted 02/04/2010 01:10AM | Edited 02/04/2010 01:11AM Opening Post
I have a coulter 13" dob with a 3.1" secondary glued to the metal plate. I am getting some astigmatism at medium to medium high power.
Could remounting the secondary with silicon help this?
Any ideas?
Posted 02/04/2010 03:46AM #1
I doubt that the fact the secondary is glued is the source of your astigmatism. Have you performed a critical alignment of the primary and secondary? Is the eyepiece a known good performer? If so I'd guess it is the primary that is the culprit. You might consider having it tested.
-Gary
Posted 02/04/2010 11:17AM #2
Coulter used a double sided tape to mount their secondaries. It holds incredibly well even years after the tape has completely dried out. I wouldn't be at all surprised to see this as your source of astigmatism. Remounting with silicon will tell you easily enough. Coulter secondaries are heavy pieces. Make sure you start with clean surfaces and allow enough time for the silicon to cure.
good luck,
dan
Posted 02/04/2010 02:58PM #3
I used to see this alot when the Coulter 13" dobs were all the rage. We would take piano wire or a sharp single-edged razor blade and cut through the mounting tape between the secondary and holder. Then we'd remount the secondary with silicon, after cleaning up the tape and carefully recentering. The mirror is not allowed to adjust to the temperature without warping when it is fastened down with tape. That tape is indeed amazing when it comes to longivity! I guess that is a GOOD thing since you don't want the secondary crashing into your primary (I've seen that happen, also!).
