Is this off-axis idea doable?
Started by BoyntonStu, 02/09/2006 04:51PM
Posted 02/09/2006 04:51PM Opening Post
Is this idea feasible?
Use a CCD as an off axis secondary. Is it possible to use software to correct the distortions caused by the off-axis angle in a pixel by pixel manipulation algorithm?
In addition, size, heating, cooling, etc. are not problems with the off-axis CCD placement.
stU
Posted 02/10/2006 03:55PM | Edited 02/13/2006 06:08PM #1
Stu,
As no one else has replied, I thought I'd give it a shot:
Without a more full explanation, it's hard for me to really know your intent, but a few things come to mind:
The diagonal of a conventional scope is far from the point at which the primary forms an image (the prime focus). Replacing the diagonal with a CCD would give a very blurred image.
Assuming you mean to place the CCD at the prime focus, using software to improve the image is a dicey proposition for astronomy because such techniques (such as deconvolution) typically increase the effects of noise, though this might not be a problem for bright objects.
In general, improving the image optically before detection has a great advantage as the detector only records the intensity of the light, and not its phase (or direction). Recording the phase information is the "trick" that makes holograms work.
I hope this helps.
Allen
