If there is a problem when mounting a new focuser because of old screw holes, is it ok to mount the focuser a little closer or further away from the primary or is it best to go across as not to change the length?
Mounting a new focuser
Started by vct, 03/07/2009 01:40AM
Posted 03/07/2009 01:40AM
Opening Post
Posted 03/07/2009 03:05AM
#2
It all depends on the focuser and whether you are happy with the current position... Do the focuser have identical heights? Can you adjust the height of the secondary mirror?
Posted 03/07/2009 04:06AM
#3
Unless one or more of the new holes is tripping over an old hole (i.e., you simply cannot drill
it because the bit cannot be positioned over partial air), then you might want to try sticking to
the old focuser location. Original holes which are too big can usually be dealt with. For example,
a short sleeve over the screw so that it positions correctly in the oversized hole.
If you simply cannot use the old location, then circumferential translation is your best bet. After
all, most secondaries can rotate 360 deg. And, it won't change your focus range nor require
moving your secondary up/down the length of the ota/uta.
Dan
Funding Member
