Orion 12 inch XTi alignment
Started by Mygatt, 12/28/2009 06:36PM
Posted 12/28/2009 06:36PM Opening Post
I just bought a used 12 inch XTi. Great views after 10 years with an 8 inch SCT. I am unable to get a Warp factor less than 14 (only once)and should be <0.5. I have disassemled the scope base and checked the installation of the encoders and magnetic rings, I double backed taped the azimuth encoder magnet as stated on other posts. I have checked the vertical stop with a level, though I had to remove the stop button and shim the handle bolt to get it level. I used an 8mm ethos to center my alignment stars not an illuminated reticle, that is next, Vega to Capella, and then the other way around. I have push to DSC's on my SCT so am familiar with how touchy they can be and need for accurate centering, but I have tried the last three nights with no luck. I have dropped a note to Orion about replacements encoders but have not heard back yet. I would appreciate your toughts. BTW, I found that the azimuth encoder was installed incorrectly and the cable plug was damaged (separated from the plug) but repaired that. I did Flock the scope and cleaned the mirror and replaced the focuser with a JMI. Nice views of the moon, Jupiter and the Ring nebula from my light polluted front yard. I can't wait to get it to my dark sky site in Eastern Washington.
Cliff Mygatt
President,
Olympic Astronomical Society
Bremerton, WA
12" Orion Dob
8" SCT
120mm F-5 Refractor
80mm WO Zenithstar II
Posted 12/28/2009 10:01PM #1
Crazy question, are you centering with the finder or the scope itself?
I have had (2) xti's, both worked great.
Sounds like an encoder issue thou.
Make sure the cables are not reversed.
