All,
I had a chance to play with one of these last night. To say that I was impressed is the reason for this thread. Optically the glass was first class. I knew the Chinese had made some improvements in their optical fabrication but these optics were on the high end of the scale. Even though the seeing wasn't the greatest, the performance stunned me. I could detect the double-double in Lyra at a mere 48X. The star images were that clean and tight. At 240X the airy disks were plainly visible with a split you could drive a truck through. Refractor like? No doubt. Delta Cygnus was easy at 133X. At 240X the split was "wide". Seeing about 5-6/10. If this is typical for the optics of these scopes the 12" is in my near future.
The mount was setup for general ALT-AZ tracking so I have not performed any GOTO tests yet but no matter where I pushed the telescope to, the mount tracked very well. I went from Pi Aquila to Izar to Antares (yes, I saw the companion) and the scope tracked on each just fine. Variable speed push button control for centering is nice. This is so much better that an EQ platform. I didn't have to concern myself with resetting the mount after an hour. I just be-bopped around the sky with no concern as to the tracking of the instrument. Pure fun.
I also found the dual speed focuser to be a very nice unit. The fine focus knob was actually useful since the the images snapped into focus. When you focused this instrument you knew you were in focus.
I have posted this for anyone considering buying one of these. So far I'm impressed. I will have access to this scope for a while. I will try to remember to give an update as to the good and bad. So far I have only good to report 8)
Though low, I will give Saturn a shot tonight.
Keith
Keith
Scopejunkie
USAF Vet
