I dont know about you guys but my visuable Paracorr is driving me nuts.Let me explain.When I collimate my Dob I can get everything to line up after laser ,sight tube ,chesire and autocollimator.Then I perform a lasered barlow procedure with Paracorr and its at least off 5mm at the diagonal faceplate.This is indicating the Paracorr is throwing it off.When I look at the construction of the Paracorr all I see is the introduction of 2 more piece of equipment in the light path to introduce misalignment ,the tube plus the loose tunable body wich is not a very tight fit can be turned and locked in many different spots.I guess the flip side is to not used one and put up with coma.Any one else having the same problems ?
thanks
gerry
thanks
gerry
