I've owned my share of long focus Newtonians in my decades long quest for Newtonian planetary perfection
As with all things, there is no free lunch. Observing from a ladder or step stool is tolerable for a time but for me grows old. I much prefer sit down observing.
If I could find a lens maker that wouldn't charge "through the roof" in the fabrication of a 40mm cemented doublet I would have a nice solution for a planetary Newtonian.
Though the idea is not new, a permanently mounted telenegative amplifier (barlow) would solve a lot of issues concerning constructing a planetary Newtonian.
1. A long focal ratio scope could be achieved with a relatively short tube.
2. The obstruction could be easily kept to 20% while fully illuminating a 1/4 degree FOV.
3. Common glasses in the barlow/corrector would keep the cost of glass low.
4. Performance of the barlow/corrector would have a diffraction limited field of 23 arc minutes (almost 1/2 degree).
5. Visual high performance could be achieved with "standard" eyepieces.
6. The resulting large image scale would be good for planetary CCD photography.
I produced such an instrument many years ago. It performed quite well but I would like to take it a step higher by using a lens designed specifically for the optic concerned thereby attaining even better on and off axis performance. Here is a 12 inch F/14 Newtonian using a standard F/5 primary. Any lens makers out there?
Keith
