Ghost of Cassiopeia
Re: check r.c. of convex surface
Started by m87, 01/27/2009 09:52PM
Posted 01/27/2009 09:52PM | Edited 01/27/2009 10:05PM Opening Post
There must be some way to do this with a laser
and a gauge block. Get some lumber scraps and
clamps and arrange them on a table so you have a
long piece that slides precisely against another
long piece in one direction. Use another piece
to make an accurate end stop for the slide.
Putty or wax the mirror to the sliding piece
parallel to the sliding direciotn. Push the sliding
piece against the end stop. Put a laser on
the table a few feet away perpendicular to
the sliding motion.
Aim the laser at the mirror and adjust/shim everything
so the laser hits roughly in the center of the mirror
and exactly goes back to the laser. Now use a
gauge block (or something with a very accurate
thickness) between the sliding wood (carrying the mirror)
and end stop to slide the mirror sideways by a very
accurate amount (like 1.000 inch). Measure how far the
laser beam reflection moved back at the laser.
Do some math and you have the answer.
m87's attachment for post 45398
Posted 01/28/2009 02:47AM #1
Hey John,
I like your thinking! I have a convex mirror, a laser and a 1.000" gauge block. I'll try your idea and see how it works.
dan
