You have it assembled correctly as far as can be seen in the photos.
If you are loosening the screws, then as has been stated, the poles sound too short.
If this is the case then there are a couple of possible sollutions depending on how much more focus travel you need.
Can you lift the EPs in the focuser enough to get focus? If you can then there is the possibility that a spacer could be placed under the focuser to gain the length needed. This would keep from having to replace the truss poles. If you can not, then there is too much length needed to try to space it and the poles would have to be replaced.
I too would contact the seller and ask why there is this problem. If it was made for Binoviewing then it should have been stated in the ad that this was the case.
