Resolution: Reflectors vs. Refractors
Started by rtroxel, 08/15/2007 06:36PM
Posted 08/15/2007 06:36PM Opening Post
smileThis is probably old stuff to some of you, but after being into this hobby for the past year, I have come to the following conclusions:
1. Reflectors can have as high a resolution as refractors of the same aperture.
2. Refractors have better contrast, making it easier to see details on planets or galaxies. However, contrast is not the same thing as resolution.
3. Reflectors can have as good resolution as refractors, but you might have to strain your eyes a little more with the reflectors.
4. Reflectors that have been properly collimated (assuming the mirror has, say, one-tenth wave correction) can actually have the same resolving power as a refractor of the same aperture.
5. In order to be properly collimated, first both mirrors must be collimated by laser, then they must be star-collimated.
6. Star-collimation: Focus a star with your highest magnification eyepiece. Next, gradually take the star out of focus. The star's image should then display Airy rings, which should be concentric. If they are not, then you need to collimate your mirrors until they do.
OK, now if someone can tell me where I'm wrong or right, that would be great! smile
12.5" Obsession w/ ArgoNavis
Orion SkyView Pro 120mm Refractor (For Sale)
w/ True-Track Drive & Intelliscope (For Sale)
Posted 08/15/2007 08:18PM #1
A minor quibble to start with. The in-focus diffraction image is an Airy disk surrounded by faint rings, and usually only the first ring is visible. The out of focus star image is a Fresnel pattern.
I am not sure why folks talk about resolution and contrast as if they were distinct, separate concerns. As detail moves toward the limit imposed by the aperture and the wave nature of light, contrast decreases. When you reach a point where the detail exceeds the resolution limit of the telescope, the contrast drops to zero, and the detail is not visible.
I suggest reading William Zmek's "Rules of Thumb for Planetary Scopes" in the July and September, 1993, issues of Sky & Telescope.
Clear skies, Alan
Posted 09/20/2007 12:33AM #2
Wrong. First of all, there are accurate tools that don't have a laser (and actually, many cheap laser collimators arrive miscollimated).
Secondly, some protocols advocated by the instruction manuals (using the return beam of an unbarlowed laser for setting tilt on the primary) yield results that aren't as good as those you obtain with a passive and cheaper tool (or a barlowed laser and screen).
Thirdly, tool collimation often reveals errors well below the tolerances needed to see coma in the star test, especially if you use a good autocollimator, but even if you use a very good Cheshire.
Finally, star testing basically only does what a Cheshire or barlowed laser does - make sure the focuser axis and optical axis intersect at the focal plane. It can't help you place your secondary optimally and it won't ensure your focal plane isn't tilted. So it's more of a sanity check of your Cheshire or barlowed laser routine than anything else (in particular, a sanity check for the placement of the centre spot on your primary).
Someone else has already pointed out the difference between a Fresnel pattern and an Airy disc (what you probalby don't realise yet is that you hav eto work at very high powers and only defocus very little).
Also, in this step you don't "collimate the mirrors", but just set the tilt of the primary, because of what I said above. You can only tune one parameter with this, and you usually pick the most convenient one (and the one that will only move the optical axis).
Posted 10/01/2007 09:50PM #3
Old stuff, old message, new response. smile
They can, but resolution is a fairly constrained characterization of a telescope's discerning ability, emphasizing the ability to preserve contrast at high spatial frequencies (very small detail). This is not an unimportant ability, especially in the area of tight doubles, but there is more to optical image quality than just resolution. Telescope A can have a better limiting resolution than telescope B, yet reveal less detail at some scales.
The usual technical description of optical quality is the modulation transfer function, or MTF. It can be thought of as a graph of contrast versus detail size. In a perfect world, contrast would always be retained 100 percent, but the world is not perfect, because diffraction causes light in the image to be spread out from where it "ought" to go. As details get small to the point where diffraction matters, contrast decreases, until you get to the resolving limit of the telescope, where it reaches zero. Broadly speaking, the MTF drops continuously from 100 percent for very large details, to 0 percent at the resolution limit. There are, of course, exceptions.
Again broadly speaking, telescopes of the same size reach 0 percent contrast at essentially the same point (the same detail size). However, the way they get to 0 percent varies. Refractors, the simple beasts that they are (in principle, at least), get to 0 in a smooth curve. Obstructed designs, on the other hand, drop faster than refractors initially, and then they rejoin the refractor curve, sometimes even exceeding it a little bit (this last part is one reason why some people try adding obstructions when trying to observe tight doubles). The main difference is in that intermediate region, where details are a few times larger than the resolution limit (e.g., a couple of arcseconds in an 8-inch scope). That's where a lot of planetary detail resides, so this is not an insignificant consideration.
All that being said, the main factor is aperture. A 5-inch refractor's MTF may be above a 5-inch reflector's MTF for a large part of the range, but they are both trumped by a 10-inch reflector (assuming comparable manufacturing tolerances, of course). That's the sense in which aperture wins.
Well, as I said, they're not the same thing, but they're not entirely distinct. Resolution is an expression of how small you can go before contrast vanishes.
On high spatial frequency objects, such as tight doubles, there is no reason why this should be true, and I've never noticed it.
That might make things easier, but no, it certainly doesn't have to be done that way--obviously, since many Newtonians have been accurately collimated since before laser collimators became available.
The whole point is to get the axis of the primary to align with the axis of the eyepiece. Everything else is mechanism. Whether you do this by star-collimation or laser-collimation or X-collimation (for whatever value of X)--the only criterion is that they align well enough to provide diffraction-limited performance. That criterion is harder to achieve for faster mirrors, and it is here that lasers can help a lot, but they aren't inherently necessary.
