Wizard Nebula
Restoring a Criterion RV-6
Started by [email protected], 06/11/2015 10:49AM
Posted 06/11/2015 10:49AM Opening Post
Hi all, as I mentioned to Andy, I found a Criterion RV-6 for a bargain. I knew right away it would need a lot of work without having even seen it in person. My 2-year old son and I took a road trip all the way out to Beverly, MA and bought the scope. Spent some time looking at sail boats... he'd never seen the ocean. Had some ice cream and headed home. All the time wondering if this would be a lemon. Would I have buyers remorse?
I've posted a photo of what it looked like on the man's porch and what it looks like after some serious cleaning. Before the sun went down I tried out some of the Criterion EPs trained on the top of my hemlock tree. I was amazed that I could see a single strand of spiders web that far away and just by chance! After the stars came out Arcturus was brilliant. Collimation seems perfect as the owner said he had recently gone through the motions. Saturns rings were very clear. Jupiter was below the trees so will have to wait for another time.
Brought it indoors and took apart the entire motor assembly and pulled apart both axis and on and on cleaning... greasing... tuning.. Some of the parts did not want to come off at first. Lots and lots of questions. How do you balance RA when the cork clutch is always engaged? What I ended up doing was putting a special bit on my drill and testing the worm gear mesh that way. There's only one speed on the Synchron motor and it's imperceptibly slow. Tried drawing lines with pencil but got impaitent. Back to the balance part. I noticed if one side was heavy the hand turned screw driver was easy going one way and hard going the other. I moved the counterweight around until it was the same effort both ways. I'm used to my CG5 mount where there's an external clutch that I can easily release and balance. It's probably in the manual...
brucesdad13@gmail.com's attachment for post 59463
~ Charlie Stevenson
8" f/5.7 String Telescope - 1st Scope Build; 2nd Place Stellafane 2016 Optical Award for Newtonians 12.5" and Smaller
10" f/4.5 Newtonian (June 2015) mirror refigured by Optic Wave Labs P-V WaveFront 1/14.24, Strehl Ratio 0.993 (Aug '15)
Criterion RV-6 seems to be circa 1973 (June 2015) [For Sale]
Celestron C8-A XLT (January 2015) [For Sale]
Celestron PowerSeeker 70AZ (Christmas 2014)
Aldrich Astronomical Society member since 2015
http://astro.charleskelleystevenson.com/
Posted 06/11/2015 05:52PM #1
Amazing what one can do if you are willing to put in the effort huh? smile
Posted 06/15/2015 04:17PM | Edited 06/15/2015 04:26PM #2
You remove the drive housing cover and then loosen the three spring-loaded clutch plate pressure screws until RA axis rotates freely. Then adjust balance weight(s). Once balanced, re-tighten the pressure adjust screws such that tube may be hand-slewed but drive tracks correctly (too loose can allow drive slippage in use with mis-tracking a result). Once clutch friction is set to your satisfaction under the stars (trial over several nights; temperature can affect final preference), replace cover. BTW, I have a 6" f/9.3 Criterion Deluxe Observatory Dynascope and an 8" f/7 Criterion RV-8. Also, the same technique applies to vintage Meade, Cave, Parks, etc drives with enclosed clutches.
