Iris Nebula
Royce 10" F/20 Dall-Kirkham
Started by lthaxton, 09/20/2008 04:06PM
Posted 09/20/2008 04:06PM Opening Post
20 September 2008
I just finished putting the Cave 8” F/8 and Royce 10” F/20 D-K away after a round with the Moon early this morning. Seeing was pretty good, 6/10 I would guess and the Royce was starting to strut its stuff. Not quite stable enough for it to hit its stride but 9 craterlets in Plato ain't half bad especially as I was catching fleeting bits of a few others. It was so nice I swapped out scopes and have the TMB 175 set for tomorrow morning.
What fascinated me was that in mono-vision the old Cave 8” F/8 seemed sharper. At one point I was running a 10mm Orthostar in it at 160x and a 40mm plossl in the Royce at 125x and they looked pretty equal though I would have given the nod to the Cave in terms of image sharpness. Running up the power it seemed like the Cave had a slight advantage and the four main craterlets in Plato were solid. But they were not bad in the Royce either, just not quite so solid. I should note that I did not run the fan in the D-K and it was definitely improving as it cooled down which it does quickly even w/o the fan running. Once cooled down, my whole outlook changed:
Things looked pretty good so I started the drives on the HGM-200. Without them it is a little hard to track given the Royce’s narrow FOV. I decided to pull the binoviewer out and WOW what a difference!! With the 30mm LEs (208x given the 1.25x Glaspar) in place the image was stunning- not dead steady as the atmosphere was a little shaky, but still a wonderful image. The craterlets in Plato were easy, 8 of them solid and the 9th fleeting. More amazing was that I was just picking up others but the air was a little too unstable to call them for certain. The image was so good I did not return to the Cave for an hour and when I did it seemed far less of a challenge to the Royce. I have no doubt that the Royce D-K was just idling waiting for better seeing! The 30mm LEs were great! They make me want a pair of 34mm Zeiss Abbes even more than ever. I was also impressed by the 24mm Panoptics.
The Royce D-K is a superb planetary scope and with the Royce 12.5" F/18 D-K prototype in the works, planetary observers should be pretty excited!
