OK, nothing special to do snd I start crunching numbers concerning secondaries and I find a problem. At present I have an 11" at 60.2" focal length, and a 1.83" Astrosystems secondary. Because of the way the holder is made it wraps around the mirror so the effective obstruction is 1 7/8" or 1.875" which is 17% obstruction very good. However, if you figure the clear portion because of the wrap you loose a bit more than 1/16" per edge or .190" total all the way around which leaves the effective clear mirror of 1.685" which the programs say is too small and I do not get full illumination. Now the next size up is 2.14 with the same type holder comes out to about 2.18" obstruction or 20% still not bad and the clear usable mirror is 1.99" which is plenty big enough (program says appox. 1.80 needed for full illumination. So here is my question. Is it worth giving up the 3% more obstruction to get the full illumination?
Thanks
Buck
Thanks
Buck
