I took delivery of my 16" f/5 astrosky (woden) reflector. My first scope was/is an Orion which, being a beginner, meant I took it out of the box and used it. I didn't get concerned with alignment other than collimation, in the roughest sense. That Orion mirror cell was a major PIA to adjust. Sooooo...I'm now learning how to set up a sling type mirror cell, mark the secondary and primary, and check to see that the focuser is square. I think I've got a handle on the first two, but checking for square on a truss dob seems to lose me. I can easily check to see that the laser dot on the opposite side of the tube is the same distance from either end, but how can I assume that the measuring points, opposite the laser line, both lie in the plane that is perpendicular to the optical axis? :S
Oh yah, man a 16" f/5 is bigger than a picture would let on. So far, that's a good thing. :b
After I get through all the set up I'll do my best to share my experience with Astrosky ie James.
