RICHARD COFER
Achro/Apo question
Started by harperr, 02/06/2007 06:48AM
Posted 02/06/2007 06:48AM Opening Post
Lens types,
A perrenial topic around here is the relative performance of an APO, or virtually perfect scope, and a longish, well made Achromat. I don't mean to raise sand gratuitously here, but as a good-achro user, I can't help but wonder what I am missing.
I would like to examine and understand the common claim that an APO will "go to" higher power while still appearing "sharp", without "image breakdown", than a good Achro. My problem is partly that as an Achro guy who doesn't get around much, I have little opportunity to make the comparison myself. Moreover, my Achro appears to me to perform very close to theoretical expectations for its aperture, which suggests the question of how much better an APO could be. There's not much I can do about the first problem, so let me concentrate on the second.
I love double stars, look at lots, and through mindless perserverance have had some success with difficult ones. From firm optical theory, my 5-inch scope produces an Airy disk, or diameter across the first dark ring, of 2.0", but my observations, as well as Rayleigh's and the similar Dawes's limits (which hold for moderately obstructed reflectors, too), indicate that a typical visible "spurious" diffraction disk of a roughly 6th magnitude star is 1.0" across in my scope. That is sure enough how it looks to me.
If this 1.0" is magnified 60x, it looks 1.0' across, still too small for me to make out. 169x makes it 2.8', big enough to see as an extended circular spot, no longer hidden in the spiky glare of aberration produced by imperfect lenses, coatings, and eye, but round and clear. The highest power I commonly use is 217x, giving a spot 3.6' across, which looks comfortably big to my reasonably good eyes.
Vision treatises say that while a normal eye can resolve two narrow black on white lines as such when their separation is only 1.0', fully 2.5-3' separation, or extent, is needed for two points to be made out, or for an extended object to be seen as in fact extended.
So, my achro and eye seem to be performing, on double stars, according to theory and well-established empirical rules for a perfect telescope and normal vision. And, from my experience and reading, including your observing reports and comments presented here, it seems the APO indeed offers no significant advantage, other than aesthetic, on these most contrasty of all astronomical targets.
My planetary views are commensurate with both my double star experience and the optical and vision "rules" as stated above. Planetary limbs, for example, look sharp at around 150x (ie, 30x/inch), but at 217x(ie, 43x/inch) are perceptibly soft. I do use 217x on Mars, just because it is so darned small, and the features, although softened by the magnification, are still easier to see because they are made big enough.
A squishy part of my attempt to connect star and planetary images is the fact that dim stars' disks look smaller, and bright ones larger, than assumed by Rayleigh and Dawes. One might suspect that low surface brightness planets should be easier to resolve, ignoring the effect that dim things are hard to see. Saturn is currently 0.0 magnitude, and 23" diameter. Consideriing the area of the rings, this works out to a bit dimmer than 6th magnitude/square arcsecond, but still close to the Dawes limit standard star. Jupiter and Mars have considerably greater surface brightness, and might be expected to appear softer-limbed than Saturn by this sort of thinking (which I am not sure is valid, but consider as an objection to my argument that could be raised).
So now I come to the APO high-magnification claims. I can believe that due to better color control, low-contrast planetary features appear more easily visible in the APO, and also colors would appear true, instead of yellowed, as in my achro. But, how can it be that APOs look "sharp" up to the 70x or so per inch frequently claimed? At that magnification the disc of a roughly 6th mag star is a whopping 5.9' in diameter. If an observer can't distinguish such a bloated image from "sharp", something must be wrong with his eyes.
It is my guess that some APO fiends are guilty in such cases, not of lying, nor blindness, but of inarticulateness. They see something in the APO that beats the achro, and inaccurately call it "sharper". Am I correct, APO heads, or is there something that I just don't get?
Ron
Posted 02/06/2007 07:43AM | Edited 02/06/2007 07:51AM #1
With the spread of the color spectrum caused by the Achromatic lens, there is loss of detail and smearing as well as loss of light in the airy disk. This will cause some loss at the EP and this will vary according to the object and the achromatic scope.
The ED shown here in this spot diagram shows this.
Any light lost is a loss in the image. The APO will have a better spot size so less light is spread or smeared.
This does not mean that you will not see a good image. My 127ED does give a very good image, but there is some loss on bright stars and objects compared to my APO.
Still I really like the ED for visual observation. Good images without huge expense.
Magnification, well I don't know, I have used 91.2x on my 127ED and it was acceptable and 60x per inch was pretty good really. But 70x per inch in the 80mm APO, well it is just too dim due to aperture.
fblue's attachment for post 111400
Posted 02/06/2007 10:10AM #2
Hello:
To me, it sounds like you're pretty happy with your scope, so I wouldn't sweat it. I'm in a similar boat. I have a scope that I like to use for planetary observations with a 33% central obstruction. A smaller secondary might help a bit, but I like the views I get so I don't worry about it.
I once asked a friend why reviews of expensive astronomy gear always seem positive, and his response is that very few people will admit that they really bought a piece of junk, or that they just wasted a lot of money. I strongly suspect that a bit of this psychology is involved. I don't doubt that expensive apochromatic refractors give very nice images (owning one myself). But I also think that the folks who have bought these need to believe that they got something extra by paying more that a less expensive scope could not provide. While this is likely the case, the differences between a fast apo and long focus refractor aren't that dramatic. In a comparison between a 3" f/16 Unitron and a 4" Takahashi on Ed Ting's page, the Tak had brighter images (bigger lens, better coatings), better contrast and more "snap" to the images. I think this is in part to the larger lens gathering 78% more light, and some is due to the achromat being an achromat. I'll finish by saying that the best I've ever seen Saturn was through an achromatic refractor. Even though it had a simple crown-flint doublet, a 16" Clark lens can provide a spectacular image!
Cheers
Mike Connelley
Posted 02/06/2007 03:03PM #3
Ron, I own a 4" achromat and a 4" doublet apo. I would not say that the apo will go higher in power than the achromat, I believe they are both following the same laws of physics. But resolution is definately noticeably better in the apo when used at the same power as the achromat. The apo focuses the light into tighter airy discs.
David E
Posted 02/08/2007 05:56AM #4
Everybody,
I guess this small chapter in the war of the refractors is about over, and I'd like to thank all who participated. I learned something from every post. There wasn't a bit of Apo snobbery or Achro defensiveness. Everybody listened, not just talked. Nobody got really silly, except possibly me. You are a classy bunch of guys.
I started the thread wondering if I should upgrade from my 5" f/12 D&G to an apo. I love that color curve jazz, but it is not like sharing real experiences. While more convinced than ever of the visual superiority of the Apo, I am also convinced that, compared to my present scope, it's a rather slim margin. Slim enough to live with. I will stick with what I've got for awhile. Hey, simple eyepieces are great at f/12!
Ron
Posted 02/08/2007 07:28PM #5
Here is a quote from another newsgroup from a perplexed individual:
"ED is like the Cabbage-patch doll industry! Keep the price high by creating shortages and mystery.
One can buy a 4" achromatic telescope for $200-$300 or lens set for lot less but now replacing one of the lens element to ED glass, price of the scope or the lens set goes up 10x. Gee!!!
Why is an ED scope more expensive? My guess is that you can get a cheap 4" for $200 - 300 because it has cheap construction and cheap lenses that are not really well made. Nobody bothers to make a cheap ED with junky construction and poorly figured optics. I mean, why bother? In actuality, a well made achromat refractor will cost 1/2 to 2/3 that of an ED, not 1/10 if construction is the same quality. Whatdaya think? Is there a market for el-cheapo ED?
Rolando
