Antares Achros
Started by mnevitt, 06/01/2008 04:29PM
Posted 06/01/2008 04:29PM Opening Post
Recently I was reading the description of various Antares refractors. I came across some terms used to describe them. "Vixen Spec", "LDA(low dispersion achro)", "ULDA(ultra low dispersion achro)", and "well corrected". Do any of these terms actually have a meaning? I would think that only Vixen could use the term "Vixen Spec" to describe its refractors.
Mark
Posted 06/02/2008 07:23PM | Edited 06/02/2008 07:32PM #1
For your information, dispersion has nothing to do with color correction. Some glass has high dispersion, some medium, some low dispersion. Some glasses have high index, some medium, some low. None of these by themselves have any affect on color error.
What one needs to make any kind of lens is at least one high dispersion element coupled to one low dispersion element. generally the high dispersion also has high index, and the low dispersion has low index.
Color correction for any two glasses is usually going to be the same as any achromat.
The only way to get better correction is to use one glass which has a partial dispersion that is equal to or close in value to its mating element, so that the color error generated by the first element is neatly cancelled by the second element. Normal glasses cannot do this. It takes one glass that has abnormal dispersion to match a normal glass so that complete cancellation of color error can take place.
Therefore, it is the partial dispersions of the two glasses that is important, not whether they are low or high. Partial dispersion is the derivative of the dispersion, for those of you who are math nuts.
Look for marketeers to glom onto this term, "Partial Dispersion" in upcoming ads wink .
Rolando
Posted 06/02/2008 11:23PM #2
Hi Mark,
I think, but I could be wrong, that Antares marketed scopes as "Semi-ED" in the past. If that's the case then they should probably put into the elite "Caveat Emptor" category. If I were in the market for a top-notch achromat I would look to D&G or get a "real" Japanese Vixen. There are other scopes like a Jaegers or a Unitron that are more rare and more pricey available occasionally.
My .02,
Steve
