Celestron OMNI XLT 120
Started by morsecode, 09/26/2007 09:09PM
Posted 09/26/2007 09:09PM Opening Post
I just received my Celestron OMNI XLT 120. Is the declination circle supposed to move? I see a screw hole but it does not have a setscrew. I tried turning the circle but it does not move.
Posted 09/27/2007 04:56AM | Edited 09/27/2007 05:08AM #1
OK, this is something I know a lot about. The dec setting circle will *usefully* be in a fixed position IF you are EXACTLY polar aligned. With exact polar alignment 90 degrees DEC is exactly due N.
In the real world, every time you set the scope up, you are a bit off true N. The best way to handle this is to adjust the DEC setting circle to the correct coordinates on a known star (Vega, Capella, whatever) once you have set up and polar aligned as best you can.
One can go further. With analog setting circles your best result will be if you re-set coordinates as you move to different parts of the sky. So if you're hunting around Sagittarius you can "locally tune" by moving to Antares in Scorpius and setting your circles for the coordinates of Antares. If you decide to move from there to Perseus, you might want to "locally tune" on one of the stars in Cassiopeia. To do this exactly you will need, in the field, the coordinates of a bunch of bright stars. By keeping your setting circles "locally tuned" you will get maximum accuracy--if you "locally tune" on Antares in Scorpius and then move to Cassiopeia, any error in your setup will be magnified. But by re-tuning in Cassipeia you will again minimize errors. When yo re-tune, you need to re-tune in both RA and Dec.
So, to sum up: The Dec setting circle should have a set screw (if you want to lock it down in an observatory context) but you will rarely use it (in most applications, where you set up and break down the scope) because movable observers are best advised to move the Dec setting circle and adjust it often.
So, if you see no way to make the Dec setting circle move, you have an issue to raise with Celestron. Shine a strong light down there and make sure there is no screw.
NOW THAT WE'VE SAID ALL THAT, there is a very easy way to use setting circles in which locally tuning and the position of the Dec circle, or for that matter, the RA circle, simply doesn't matter.
If you have a reasonable star chart like Sky Atlas 2000, flip it open to Lyra. Look at Vega. Now look at where M57 is. You will notice that to get to M57 from Vega you need to move from about 18:37 in RA to 18:53. The difference, then, is 15 minutes in RA. All you have to do is move 15 minutes E from Vega and then head due South from Dec +38:49 to +33:00. That's about 5 degrees and 3/4 of one degree more. Looking at your dec markings, you can do that. You can count off in Dec or, as you get close, just look in the eyepiece and continue to sweep.
In other words, you don't need EXACT coordinates and EXACT positioning of your setting circles to find stuff, because with your star chart you can get the ANGLE you need to move and ANY of the measurements on the analog setting circles will help you get the ANGLE provided that you remember you are looking to count off the difference--5 3/4 degrees--not move from the exactly designated position of Vega (18:37 +38:48) to the exactly designated postion of M57 (18:53 +33). When you move South 5 3/4 degrees it doesn't matter if your dec circle says you are starting from 40 or -22 +38:48 or whatever. The important thing is simply to look at the markings (never mind the numbers) and move 5 3/4 degrees.
There is some inaccuracy in this estimation technique and it is "friendliest" in wide field refractors but I have used it, with some care, in a c14, which is only 3/4 of a degree field of view. In my refractors I have 2.7 degrees in one and 4.25 degrees in the other, which is huge, and provides for a lot of slop. You have two potential sources of error, a bit of estimate error on the star chart, and a bit on the actual setting circles.
So you can blow off having your setting circles accurately set if you use them instead as angle counters to get from one known point to your destination. For this to work you need a good star chart.
It is more complicated to DESCRIBE than it is to DO, but you can move around pretty quickly once you get the hang of it, and it is a technique that occupies the gray zone between star hopping and using a computer (you are using an analog computer to measure angles).
The "Dec sweep technique" eliminates the need for measuring in Dec altogether. You go to the approximate RA and sweep till you hit the object. My impression is that the Dec sweep technique is best for brighter objects but with refinement you should be able to do just about anything.
So long as you are "on the same page" of your sky atlas 2000 (as in moving from Vega to M57) you will automatically have "local compensation" for distortions caused by slight polar misalignment.
It is helpful to know the field of view your telescope provides with its widest field eyepiece, which is basically your error tolerance with these techniques.
So, to conclude:
--In some contexts the Dec circle should not move (permanent observatory set ups).
--In most cases it should. That's the best way to get the most accuracy.
--If you learn the angle measurement technique you won't care.
Nonetheless, my preference would be to have a Dec setting circle I know I can adjust, as sometimes, it's nice to set it all up so you can use the coordinates as you read them. But on the process involves keeping a lot of numbers in your head and usually the easiest thing to do is some form of angle measurement or dec sweep.
regards
Greg N
