Iris Nebula
CHROMACOR Collimation w/ off the shelf parts
Started by Doug Peterson, 05/08/2008 04:20AM
Posted 05/08/2008 04:20AM | Edited 05/09/2008 11:38AM Opening Post
The chromacor color corrector that turns an achromat into an APO is one of the coolest developments in amateur instruments. However I find the collimation method of futzing around till you get it right cumbersome. I want a deterministic method of collimation on the star test just like collimating an objective, that is, three pairs of push-pull screws at the focuser so adjustments and tweaks can be done live.
1) The only focuser I know that has built in collimation for refractors is the Moonlight. Excellent focusers but screws are on the inside, so you must completely remove the focuser, tweak the collimation screws then replace.
2) Another idea I have involves a collimatable diagonal, but tricky to implement because the chromacorr must come after the mirror.
3) I finally found some inexpensive commerical parts that will allow for tip-tilt at the back of the focuser.
First here is a photo of the ScopeStuff adapter ring meant for use in replacing a Synta/Orion focuser with a GSO dual speed Crayford ($39.00 - #FNCI - Adapter Ring with Hardware for 2" Crayford Focuser); the silver ring is shown between the newtonian base and a standard GSO.
But instead, if you remove your 4" OD Synta/Orion/Celestron refractor focuser body, and install the ring using its three radial screws, you now have a foundation to install the Synta/Orion collimatable 2" Crayford focuser in the Second picture.
Doug Peterson's attachment for post 41982
"--Granted, that's a worse case scenario. The destruction might in fact be ... limited to our own galaxy."
Posted 05/08/2008 04:24AM | Edited 05/10/2008 06:06PM #1
Here's the focuser: Remove it from its base and install on the adapter ring. NOTE: the cyclindrical body of the focuser will not fit inside the ring, therefore .45" longer 3mm push screws must be used. Because of this I like the next solution better.
Doug Peterson's attachment for post 122263
Posted 05/21/2008 01:49PM #2
Doug;
I have been regularly using a chromacor for the past several years with my 6" F8 Jaegers.
Before purchasing the chromacor I squared up the tube, installed an AP 2.7" focuser & it has been a plug & play device ever since. I have never had any problems with flaring.
I experimented for a while with different diagonals & adapters but found the differences to be insignificant.
So once you get the focuser square and the lens collimated, I think you'll be good to go. All the best, Bill
