Cleaning a Fluorite Doublet
Started by peleuba, 08/01/2007 03:56PM
Posted 08/01/2007 03:56PM | Edited 08/01/2007 03:58PM Opening Post
I have a couple of Celestron C102F's that am doing head-to-head A/B comparisons. One sample of is especially dirty and I woud like to clean the outer two surfaces of the doublet objective that are exposed to the air. I am not taking the lens apart, only unscrewing the entire lens cell assembly from the tube and then cleaning the the outer two surfaces. I use the Astro-Physics optical cleaning kit:
http://tinyurl.com/eo9vv
Am I o.k. with lightly cleaning the Fluorite element? It is uncoated. Surely this had to have been cleaned when the scope was initially assembled.
Thanks.
Posted 08/01/2007 06:33PM #1
It's OK to clean it as long as you don't use canned air. It can be so cold after expansion that it could crack the fluorite.
Dmitri
Posted 08/02/2007 11:17PM #2
I removed and cleaned the fluorite element uncoated of a doublet, and had no problems using the usual common sense, plus:
Resist the temptation to "huff" the lens with your breath, or water, which can attack fluorite. Use technical grade acetone or isopropyl alchool and kleenex. Use thin plastic gloves.
"--Granted, that's a worse case scenario. The destruction might in fact be ... limited to our own galaxy."
