More star testing
Started by fblue, 10/13/2006 05:30AM
Posted 10/13/2006 05:30AM | Edited 10/13/2006 05:31AM Opening Post
Well, the clouds moved in after about 30 minutes, but I did get a chance to do some more star testing on the 127ED.
I used Altair because it was in a good area of the sky and the air was pretty steady in that part.
I tried to use a 4mm (285x) but the conditions were not good enough to give me crisp rings. So I ended up using a 5mm (228x) TMB/BO EP and did quite a few runs in and out of focus looking for any changes in the rings.
First thing that I noticed was that the blue separated early on the inside of focus. This was obvious with 2-3 rings but disappeared with 4 rings. Outside of focus did not show this color separation.
The next thing that I noticed was that the rings were basically identical on both sides of focus. There was no sign of any aberration, turned edge, correction or spherical. I am pretty amazed that the scope tests this well. The diffraction rings are as nice as I see with my Zambuto mirrors, minus the central obstruction.
I also found that Altair a .8 mag star showed no color around it when in focus. Nothing like a halo or ring could be seen. Vega, a 0 mag star, did show a slight amount of blue or purple, but no halo or ring, just a slight hazy of color around it. This seemed to almost disappear when focus was perfect.
I also found that when I switched to the Radian EP, the diffraction rings were more sharp and easier to read, which was an interesting find. The difference was fairly large, with much better definition. I did not have a Plossl or Ortho of 5mm to try so these were the only EP used.
Then the clouds moved in and covered all my sky cwy so I put the scope away again.
I can not wait to get it out on a good night with clear and dark skies. But the forecast for the weekend is not good. :S
Posted 10/13/2006 07:28AM #1
Impressive! You got a winner there!
Posted 10/13/2006 03:49PM #2
Floyd,
I too have noticed that my one Radian (a 10mm), as well as my other Naglers, give better looking star tests than other budget brands at the same or comparable focal length. It does not mean I've tossed my budget brands though. I prefer my BO/TMB's for planetary use because of their subdued later color. On most other targets I like using the Televues.
David E
