Oil spaced & Air spaced
Started by zoisite, 03/04/2007 02:13PM
Posted 03/04/2007 02:13PM Opening Post
Why would an Oil spaced triplet using FPL-53 exhibit a slight amount of CA, while an air spaced triplet using OK-4 does not?
I've been considering a TEC 140 which gets excellent reviews, but am very curious about this.
Posted 03/04/2007 06:42PM #1
The air spaces allow the designer two more
surfaces to "play with" for adjustment of
aberrations. But the extra air-glass surfaces also
require more careful figuring of the glass and
more sufaces to be coated, so it may cost more $.
It also depends on what glasses are chosen for the
other elements -- just having FPL-53 or OK-4 does
not make the lens.
Posted 07/13/2007 02:16AM #2
"Why would an Oil spaced triplet using FPL-53 exhibit a slight amount of CA, while an air spaced triplet using OK-4 does not?"
Were you comparing two 140 F/7 lenses one oil spaced and the other air spaced?
Vahe
