Wizard Nebula
Pinched lense- can it deform lense?
Started by adamsdp, 02/21/2006 12:58AM
Posted 02/21/2006 12:58AM Opening Post
I have a Borg 101ED that I recently collimated and after checking it using a Pico Star indoors, the diffraction rings indicate a small amount of pinched optics. I prefer to leave the collimation screws slightly on the tight side in order to avoid having to recollimate. I am wondering if leaving the lense with stress on it could deform the lense over time? If there is any risk of this, I will loosen up the screws and take my chances on having to collimate more often. Thanks.
Dave Adams
Posted 02/21/2006 01:53AM #1
Dave,
Let me get this right... You prefer to use the scope with the lens pinched only so you don't have to re-collimate in the future? Why collimate to begin with, if you don't care how it performs? While I don't believe it will cause a permanent distortion of the lens, I think the lens (especially the soft ED glass) can crack under extreme temperatures or temprature change. I would loosen the screws a bit, it should still keep collimation pretty well for a long time.
oren.
