Jay Messeroff
Lunar & Solar Transits
Spot diagrams / How do you read them? Pt. #1
Started by aaronsland, 11/01/2007 04:20AM
Posted 11/01/2007 04:20AM Opening Post
I asked a question and this is the answer I was given. Can someone please shed some light on how to read this.
aaronsland's attachment for post 39483
Nothing in education is so astonishing as the amount of ignorance it accumulates in the form of inert facts.
Posted 11/01/2007 02:08PM #1
Spot diagrams show how an optic focus various colors of light. It is based only on the theroectical performance of the design, not on errors in workmanship or flaws in the glass. The diagrams you have been given appear to be for a refractor. Blue light is on the left, infrared is on the right. The image has been focused for green light (centre column).
The top horizontal row is the "on axis" plot. It shows how the various wavelengths of light are focused in the centre of the optical path, "on axis". Note that when green is focused, there is an expanding amount of defocus across the spectrum, ( secondary color)
The middle horizontal row is for points that are 0.25 degrees off axis and the bottom row is for points that are 0.5 degrees off axis. Note that the green light off axis is starting to stretch out. The optic is no longer creating nice sharp pin points. This is due to the optics design leaving uncorrected astigmatism and/or coma.
Inside each spot is a small circle representing the Airy disk. A scope cannot create a spot smaller than the Airy disk and if all points are inside the circle then that is as good as it can be.
hope this helps,
dan
