TOA 130 Collimation
Started by higbyrichard, 06/27/2011 03:34AM
Posted 06/27/2011 03:34AM Opening Post
Has anyone had an experience collimating a Takahashi TOA scope? I am just about to tackle this as after a heavy bump stars are now Comets complete with tails.
Some post on other forums are conflicting as to whether it is possible or not. There are some indications that it is not practical with the TOA optical system. Returning the scope to Japan from Australia has to be my last and expensive option.
Thoughts or advice would be appreciated.
Richard.
Posted 06/27/2011 06:00PM #1
Get a hold of Texas Nautical Repair (TNR). They can tell you the process for Collimating the TOA or they can do it at significant cost savings over a trip to Japan. They are the only authorized Takahashi distributor/service center.
See the link:
http://www.takahashiamerica.com/index.htm
Scott Busby
A.K.A. Reconair
Carpe Noctum
Mortal as I am, I know that I am born for a day. But when I follow at my pleasure the serried multitude of the stars in their circular course, my feet no longer touch the earth.
- Ptolemy,c.150 AD
Posted 06/27/2011 08:57PM #2
Ouch! That sucks. If it's coma you're seeing now, elements may have gotten de-centered or wedged.
Jeff
"Don't sweat the petty things and don't pet the sweaty things" 8O
Posted 06/30/2011 05:37PM #3
Richard,
Having dealt with optics for some years now and if I owned the scope, I would remove the cell from the scope and very lightly tap around the cell with a rubber mallot to see if this will reset one of the elements which could be the problem from the hard knock. If your very careful, this should do no damage to the glass. You may have to slightly loosen the cell retaining ring first.
Posted 07/05/2011 08:09AM #4
Here are links to a couple of threads where Herr Rohr talks about recentering triplets. While he's doing this indoors it seems that you might be able to try making very small adjustments to the centre lens while obseving the coma on a real star. It's interesting reading anyway.
http://translate.googleusercontent.com/translate_c?hl=en&prev=/search%3Fq%3Dastro%2Bforen%26hl%3Den%26rls%3Dcom.microsoft:en-au:IE-SearchBox%26rlz%3D1I7ADRA_en%26prmd%3Dvdf&rurl=translate.google.com.au&sl=de&twu=1&u=http://www.astro-foren.de/showthread.php%3Fp%3D54500&usg=ALkJrhiRg1VxRsCL_FWfRPsDcnBU4_FPhA#post54500
http://translate.googleusercontent.com/translate_c?hl=en&prev=/search%3Fq%3Dastro%2Bforen%26hl%3Den%26rls%3Dcom.microsoft:en-au:IE-SearchBox%26rlz%3D1I7ADRA_en%26prmd%3Dvdf&rurl=translate.google.com.au&sl=de&twu=1&u=http://www.astro-foren.de/showthread.php%3Fp%3D41561&usg=ALkJrhj4lV1wH3rpKBURrEsNufdrau-cBg#post41561
