Mark Eby
M33 Triangulum Galaxy
Why is a field flattener used w/ refractor?
Started by thoth11, 09/23/2005 06:12AM
Posted 09/23/2005 06:12AM | Edited 09/23/2005 06:14AM Opening Post
I've been looking for a 2" barlow to aid use for both visual and dslr photography. I found an AP barlow that should work or I'll get a TV Big Barlow.
AP's website also shows the 2.7" and 4" field flatteners. I'm just wondering why the use? I guess it seems odd a flattener is used with a refractor. I'm just looking for some basic info. I've purchased a new dslr and soon will be ready for 3 or 4 minute long exposures. I'm just using a meade 102ed with a 2" focuser so it's not really anything I can use but I'm curious.
What barlow is preferred for photo use - AP or TV?
Thanks for your help.
Don
Posted 09/23/2005 11:41AM #1
AP refractors are designed for widefield imaging. To get the sharp edges, especially with a larger format camera, a field flattner is a big help.
As far as a barlow, that will double the effective focal ratio of your scope and so exposure time will be quadrupled. with all those pixels, I am not sure a barlow will be a help, especially if the mount does not track perfectly, you will probably loose more in the long exposure than you gain with by the higher nominal magnification.
Posted 09/24/2005 01:59PM | Edited 09/24/2005 02:02PM #2
If you do someday try wide-field imaging with the dslr,
you can get the TV 0.8x reducer/flattener designed for the
TV 102; its got 2" on the front end and T-thread on the
back end. Most refractors have field curvature with
radius about 1/3 the focal length, so any 102 F/7 to
F/10 should work fine with it. Won't need it of course
for lunar and planetary; there you probably want a Barlow
or PowerMate to make the image larger. As mentioned by Jon,
you don't need a 2" Barlow; 1.25" will work fine.
