Here I am pushing glass the hard way, by hand. Actually, I have never used a machine of any type, primarily because I don't have room to store one. I am working this one in the sink in my darkroom. I usually walk the barrel but it's been so darn hot here in FL that I decided to take advantage of the a/c!! This is the first truly thin mirror I've worked so it's all new to me so far, and I am learning already. I started much too soon with the 10" tool. Should have hogged the center out with my 4" iron tool to a greater depth first. I'm at the right RC now, 192", but still need another 1.7" to the edge. I'm almost out of 60 grit. Would I be ok to continue on with 80 to finish up the curve to the edge and then proceed on to 120? Also, would I be better off with a 12" or 14" tool once I get the full curve and diameter finished or is the 10" sufficient? I'm still using the carpet to support, but as soon as I can get some of the bubble wrap I may switch to that. The little bit I had to see how it looked wasn't quite enough to give full diameter support.
Walt
Walt
