18 inch Kriegsonian project
Started by Phil Barker, 12/06/2005 03:12AM
Posted 12/06/2005 03:12AM | Edited 12/06/2005 03:13AM Opening Post
Getting along nicely with the truss tubed 18 inch f-5 scope I'm building.
I have just begun polishing the big 30mm thick plate blank.
I've also been making the scope itself out of a sheet of 17mm plywood.
All cut with hand held jig the bearings are 19 inches in diameter which is adequate in my opinion.
I'm keeping the costs down by making most of it including the mirror sling spider and possibly the finder but will be using a williams optical focuser.
Will be using formica on teflon for the bearing. i hope to cut out the rocker box later this week.
As to the mirror I will be testing figuring with the mirror slung. hope to do final startesting in the scope.
note the open back i will install a fan at some stage
Phil Barker's attachment for post 28506
Posted 12/06/2005 03:16AM | Edited 12/06/2005 03:20AM #1
here's the mirror box showing the inside and open back
Phil Barker's attachment for post 98855
Posted 12/07/2005 04:53PM #2
Thanks John a very good reference page. I'll be digesting its contents carfully.
The parabolising gets tougher the bigger you go but I reakon I can make a decent go of it the last 2 mirrors I did were 16 inches in aperture.
Phil B
