1st Telescope problems
Started by RichTom, 03/15/2004 11:47PM
Posted 03/15/2004 11:47PM Opening Post
Greetings All,
My son and I bought a 125 mm primary mirror along with a secondary mirror & associated mirror mounts, the mirrors are supposed to be made by Meade. We were able to put everything together using a Sona Tube, but the images appears "fuzzy" especially at high power. I found Mars under low power (25 mm), but when I use high power (9 mm), instead of seeing one larger image, I see several cirlces which almost seem to pulsate. A friend at work said I might need to columate (spelling?). I would appreciated any suggestions in this area. The mirrors were wrapped in paper towels when I got them. I used compressed air to clean them off, but did not wash them at my friends suggestion. Perhaps the mirrors need a good cleaning as well. Thanks for any help you can give.
Posted 03/16/2004 03:35AM #1
Either the scope has a very bad case of spherical aberration, or (more likely) the problem is in focusing. You probably need to refocus when switching between the two eyepieces. Also, the focuser may not have sufficient in-focus (towards the tube) travel. If that is the problem, you can have it fixed by moving the primary slightly closer to the front tube opening.
Just a couple of possibilities...
