Shane Yarnall
LDN 1622
8 inch figuring woes
Started by djscobel, 05/14/2003 01:34PM
Posted 05/14/2003 01:34PM Opening Post
For the third time in the past several years, I'm attempting to refigure an 8" f/8 mirror. Every time I have tried I've run into the same problem. No matter what I do, no matter what stokes I use, I end up with a hill in the middle of the mirror. Sometimes broad, sometimes narrow, but always there, and always too large to ignore (I'll be using a 1" minor axis diagonal).
The mirror is completely polished out to the edge. I'm hand polishing on a channeled full sized lap (on Pyrex tool), mirror on top. Gugolz #73 pitch. Facets are 3/4", spaced 1/4". I use netting to microfacet the surface of the lap for better contact/conformity. Polishing with cerium oxide. The basement where I'm working is usually between 62 and 64 degrees F., with between 70 and 75% relative humidity.
I don't think that lack of contact is the problem. I always start the session by pressing. Earlier in the project I would leave the mirror on the lap overnight and wrap them with wet towels to prevent drying. Now I've been starting out by hot pressing, and commencing work before all the heat has gone out of the mirror/tool. In either case, I would polish for short periods, 5 minutes at most, then cold press for 5+ minutes before polishing some more, to maintain contact. There's no slipping and grabbing - the feel is good and even. No ripple nor dog biscuit either.
1/3 W or center over center strokes always leave the mirror severely oblate spheroid with turned up (yes, up) edge. Longer (1/2 dia. or longer) W or center over center strokes tend to flatten the edges, but I still end up with a broad hill about 4" in diameter. Really long parabolizing strokes with lots of overhang side to side tend to leave the center of the mirror too shallow, and with a smaller (maybe 1.5 - 2") hill in the middle.
Getting to a sphere has been all but impossible. Use of a lot of overhang, and doing most of the polishing in the overhang position reduces but does not eliminate the hill. To get it to go away completely I have to go so far over to the edge that I invariably dig a ragged hole.
Another curiosity is that no matter how much long strokes I use, I have never turned the edge. I always have a good diffraction ring all the way around. In fact, too much short strokes (1/3 - 1/2 dia) always leave the edge turned up.
It's almost as if the only part of the lap that is working is the extreme edge. I can control the width of the hill by varying the amount of overhang side to side that I use. Using more overhang will leave a narrower hill - less overhang leaves a broader hill.
I theorize that my pitch is too hard? That would explain why I have not turned the edge. Is there anything else that could explain why I'm getting the hill? In all the books I have (Texereau, Thompson, Howard, Ingalls, Berry), none of them explain what might create a central hill, only how to treat it (which never seems to work as described).
Posted 05/14/2003 08:16PM #1
I think your theory is correct. The fact about polilshing pitch is that it does not flow very well unless you get to the melting point. Gugolz 73 has a melting point of 77-80 C. Even with all the work you are putting into your strokes, the 64 C room is killing you. You could heat the lap in hot water (77 - 80 C)for 5 to 10 minutes then press,then work. But, given the temp of your environment try getting some Gugolz 64. It has a melting temp of 68-72 C. You can even temper it with some Gugolz 55 (52-55 C). You should get better contact with the center with this. In addition, as you use a slightly longer 1/3 COC stroke to hammer the hill, don't be afraid to put your body into it. You have to generate some heat to get that glass to move.
I had a similar problem on my first mirror. It turns out I was being way too soft with the strokes.
Good Luck!
Posted 05/20/2003 07:23PM #2
Thanks to all who responded. It turns out that indeed the lap was too hard. I've since moved upstairs to the kitchen (to my wife's chagrin) where it's warmer, plus I'm using softer pitch. Things are now working much better, I actually dug a hole in the middle of the mirror by using a too long stroke (which would have still left a hill in previous efforts)! I'm finally on my way. Yippee!
