Hi Folks,
After reading Keith's posts, I finally got motivated to work on my 8" scope also
I decided to use the same method of heavy wall paper tube and wood parts that Keith used, as it would be easy to modify, and a cheap way to get the scope built while I finalize the drawings for the metal shop. End plates and lense mounting rings are both routed from 8 layer plywood.
I was surprised the collimation was very close for my astigmatic eyes, so no adjustments yet.
As an f6 it makes a good comet-finder type scope. Yep, easy to spot chromatic aberration on mag 0 stars, but for deep sky fuzzies, it is not noticeable. I think there is some spherical aberration, and critical star testing has yet to be done. Saturn did show a bunch of moons though.
I setup the scope last night in the front yard, (street lights –bah !) to look for Galaxies around Virgo/Leo. Just sweeping back and forth (1.75 degree FOV) I counted 28 obvious ones without checking at a star map. I did need a map inside Leo, and saw 5 more without too much effort. The fun part was seeing the groups of galaxies together, three or four at a time.
The mount is a Lightspeed "Wagon" fork mount, that seems to handle the scope without too much shaking. Length of scope is about 42" with racked in focuser. Weight somewhere around 25lbs. Setup time was a few minutes, and no counter weights !! Tube painting, inside flocking and baffles to follow later.
David Simons
