a few questions
Started by splisi, 05/24/2006 12:14AM
Posted 05/24/2006 12:14AM Opening Post
Hello, I'm just making my first telescope, and I don't really have any experience with making anything, so please bear with me if these are really stupid questions (and I suspect they are).
Anyway, the design calls for pairs of push-pull bolts, but I can't seem to find them anywhere, and when I search online I get hits about using them in ATM designs but not actually what they are. Again, sorry if this is extremely inane but I'm at a loss here. I tried www.mcmaster.com, and at every hardware store I've been to I can't find anything going by that name. Any help would be appreciated.
Also, I require a piece of phenolic tubing, 7" outside diameter and 50" in length. If anyone could direct me to somewhere online that would sell something like this I would be grateful.
As I go through this, I'm likely to have more questions, so I'll post them here, and hopefully you kind folk can help me out. Thanks.
Posted 05/24/2006 04:44AM #1
I'm new at this astronomy thing too but I will try answer what I can.
The push/pull screws are seperate from each other, one set pushes and on set pulls. In other words in the mirror plate you should have some thread inserts (T-nuts) into which screws (pull) that go through the bottom of the cell with a spring in between.
The push screws have their threads in the cell bottom and go up and push up on the mirror plate. Thus one set (usually 3 in each set, depending on mirror size) pulls down and the other pushes up thus holding the mirror in place.
As for the tubing you might try this web site http://www.magnumrockets.com/airtube.html scroll down to Public Missles, they have some 7.51' tubing but the shipping could be a killer.
The "star" we look at tonight may have exploded millenniums ago. (To progress, we must discern what exists and what does not).
Posted 05/24/2006 04:49AM #2
Not exactly the dimensions you're looking for, but these are made specifically for Newtonian OTA construction...
http://www.fpi-protostar.com/blite.htm
Duane
Posted 05/24/2006 12:56PM #3
Hello:
Push-pull screws are a pair of ordinary screws used together. Some older style mirror cells use 3 pairs, mounted 120 degrees apart. For each pair, one scew is threaded into the back plate of the telescope to push on the mirror cell, and the other is threaded into the mirror cell, to pull on it. Both screws are parallel and next to eachother, and the head of each screw is at the back plate of the telescope. An alternative to using push-pull bolt pairs is to just use a pull bolt with a spring to provide the push.
For 7" tubing, have you looked into local sources? Places that provide concrete forms is the traditional source of dobsonian tubes.
Cheers
Mike Connelley
