Aluminum scope tubes and Powder Coating!
Started by mpupeza, 03/11/2009 01:58PM
Posted 03/11/2009 01:58PM Opening Post
The recent discussion on Powder Coating reminded me of a few suggestions for ATMs changing out, or making new scope tubes.
I changed out my old 12" hybrid cardboard, fiberglass, aluminum sheet 48" long scope tube, which had many extra holes, bangs, chips, scrapes, etc., for an aluminum tube ordered from Hastings Pipe Company.
I ordered the .094' thickness, but should have ordered the .064" thickness. .094" is too heavy for my 12" dia. X 48" length. On my old Meade Starfinder GEM, even sliding the 25# weight to the end of the shaft wasn't enough, so I found an additional 8# weight and then balanced it out.
Using the .064" would have saved about 7# and the added weight wouldn't have been needed.
My consolation is that my scope is as sturdy as a tank!
Oh yes, I had the tube powder coated in Melbourne FL for about $80 - so the tube plus coating came to about $200. Again, cost saving for the thinner tube would have been about $25.
The powder coating is an excellent way of going. It's about the same price that I was quoted from an Auto Body Shop for painting and I've been pleased.
Black auto body lip edging trims out the ends and makes it look pretty good!
At the Winter Star Party, I got some pretty good viewing in, especially after I installed the extra counterweight!
Mike
6" f6 homemade NEWT on old Meade GEM
10" f4.5 homemade NEWT on old Meade Mount
Posted 03/11/2009 08:29PM #1
Mike,
What have you done for the inside of the tube? That is, what sort of light "absorbing"
anti-reflection treatment did you do for the inside? While I know that there are
flat black powder coats, I've never seen one to evaluate just how flat it is and have
assumed that a different treatment is done for the inside of the tube. Of course, this
all assumes that this is a concern for you.
Dan
P.S. So what color did you go with?
