Zoiks! Apple ply is twice as expensive as BBB grade baltic birch. Is it twice as good? BBB means one side is free of plugs and the other may have some, but few. Opinions?
apple ply versus baltic birch
Started by toml, 10/02/2003 01:23AM
Posted 10/02/2003 01:23AM
Opening Post
Posted 10/02/2003 03:31AM
#1
I haven't used much Apple Ply, but lots of Baltic birch, also known as Finn birch. Both have hardwood multi-ply cores and water resistant glue. Apple may be maple, I'm not sure. Apple is prettier, and available in 4' X 8' sheets, while the birch is available in 5' X 5' and 8' X 4' [cross sanded] sheets. The birch comes in 1/16", 1/8", 1/4", 3/8", 1/2", 3/4" and 1" thicknesses, or the metric equivalents. Both plies are very rigid and strong. The edges are attractive without requiring banding, and voids are rare.
Baltic birch is less expensive, last I looked about $30 for a 5' X 5' X 1/2" sheet from my supplier.
Posted 10/02/2003 03:42AM
#2
I thought ApplePly is more like 3-4X Baltic Birch in price, after special freight (from www.aitwood.com), and cannot be purchased pre-cut or in smaller sizes. Whereas BB is available pre-cut and UPS-shipped. I even posted a wanted ad for small/scrap ApplePly, and recently someone else did the same...
ApplePly is supposed to be lighter.
-- William
-- William
Posted 10/02/2003 08:39AM
#3
Appleply is both lighter and stiffer than Baltic birch. The difference in weight is noticeable just hefting two comparable sized pieces in your two hands. You can make up for stiffness, if necessitated by your telescope design, by using more Baltic birch (laminating pieces together), but then the resulting scope is even heavier.
Still, I've decided it's not worth 2x the price unless you want the natural maple finish of Appleply for its beauty or the resulting scope will be too heavy if you go with Baltic birch.
Funding Member
