Philip Imbrogno
Elephant Trunk Nebula
Attaching mirror to the cell with glue?
Started by Craig Burlette, 02/24/2005 02:57PM
Posted 02/24/2005 02:57PM Opening Post
After reading the Sky & Telescope article on designing mirror cells using a program called "PLOP" I've decided that my UO cell is a less than optimal design. One question I have is how secure and safe is it to attach the mirror to the cell using silicone adhesive? Has anyone done this, or has anyone had their mirror come loose? What is the preferable adhesive, RTV?
Thanks in advance
Craig Burlette
Posted 02/24/2005 03:38PM #1
Craig - According to reviews I have read about Portaballs, Peter Smitka ( of Mag1 Instruments) attaches the Zambuto mirrors in his Portaballs with silicon (I am only assuming that it is RTV). You might send him an email and verify what he uses. He has always been friendly and responsive to any queries I have sent him.
Posted 02/24/2005 06:09PM #2
Try this. Take a soda bottle and a board and place a one inch dob of silicone on the bottom of the bottle then place it on the board. Turn the bottle just a bit to insure that the glue makes good contact. Now let it sit for 24 hours. Now try to pull the bottle off the board. If it is put on well it will be very hard to pull loose. You might not even be able to do it!
I have attached a few mirrors with silicone and as long as the surfaces are clean and the glue makes good contact and proper cure times are observed, then it will hold anything. Be sure to use a fresh tube of silicone RTV.
I have also made 180 gallon aquariums from glass I cut and just RTV to glue them edge to edge and they never leaked or let go at the seams. That is 1350 pounds of water!
Posted 02/25/2005 01:25AM #3
Hi Craig,
That's my mirror cell in the Sky and Telescope article. I've attached scores of mirrors (as large as 18") to mirror cells (3, 6, and 18 points) using silicone. Here is my procedure.
Prepare a clean padded surface for the primary mirror. Place the primary face down on this clean, non-abrasive surface. Make sure that the mirror is level.
The surfaces of the support pads and back of the primary mirror must be clean and free from grease, dirt, etc. Acetone can be used to remove grease, but it is not effective for removing silicone and other contaminants. The best surface is one that has been abraded to expose fresh material. Be careful not to get any sanding grit under the mirror. It will do great, irreversible damage to your mirror.
With the primary mirror face down, center the mirror cell on the back of it. Mark the location of the support pads. Turn the mirror cell pad side up and abrade each pad with 60 grit sandpaper. Sanding the location of each pad on the back of your mirror will also create a better bond between the silicone and the glass.
I use the GE (General Electric) 100% Silicone Type II outdoor sealant to attach mirrors to the support pads. It is used for filing the voids around tubs and tiles (their Kitchen and Bath variety) or around windows and doors (sold as their Windows and Doors variety). I suspect they are the same. These sealants are sold in a variety of colors. I have used clear, white, black, and gray. They all seem to perform the same, but I prefer the clear Windows and Doors variety. The same material is also available in small tubes under the name of 100% Silicone Type II Sealant/Household Glue.
Apply a thin coat of silicone sealant to each pad. Invert the mirror cell so that the pads come down onto the alignment marks you made on the back of the mirror. Allow the weight of the mirror cell to apply the correct pressure. The silicone sealant should wet out the entire surface of the support pads and ooze a small amount beyond their edges. The thickness of the silicone is less than 1mm. Double check that the mirror cell is centered. If your mirror is not level, the mirror cell can float out of position. Allow the silicone sealant to cure fully – usually overnight – before moving.
After waiting 24 hours, carefully test that the silicone has completely cured. Then install the mirror and its cell into the mirror box.
I design the mirror cells so that the total area of all the support pads glued to the back of the mirror is approximately 2-3% of the mirror area. That doesn't sound like a lot, but it does the job real well.
By the way, you shouldn't be too concerned if your mirror cell isn't the optimum design. The key question is whether the cell will do the job.
Albert
