I took apart an old pair of Bausch & Lomb 6x30 binoculars last week and made the mistake of using a pair of pliers on one of the eyepiece tubes. Needless to say, I bent the tube severely out of round. I was able to get it back to a basic circle by gently hammering a metric socket through it. However, I still can't get the eyepiece to fit over the eyepiece tube. I can get it started, but it just isn't a gentle fit. My next step has been to procure a couple of dowels and a piece of scrap 2x4. The hardware store guy suggested that I heat the piece with a heat gun and then roll it on the 2x4 using the dowel. However, since I don't have a heat gun, I've been trying to heat it up on the gas stove and then roll it. (Hmmm...if they aren't frying turkeys, I guess this is how most rednecks burn down their homes?
) Anyway, I'm not making much progress. How hot do I need to get this eyepiece tube? If I heat it up too much will it melt completely? Is there some kind of special wrench that I should have used?
My plan B would be to cut off the tube and superglue a piece of plastic tube from one of my wife's perfume bottles in its place. However, this would not be aesthetically pleasing. Is there some other standard piece that I should just use instead? These are not WW2 individual eyepiece focus binoculars so I don't think that the Surplus Shed has a part in stock for these.
Lesson Learned: Don't use Pliers on a Brass Tube.
[SIZE="Small"]------------
[/SIZE]
