james carter
North American Nebula NGC7000
baffle for a nasmyth cassegrain
Started by Phil Barker, 04/22/2009 03:37AM
Posted 04/22/2009 03:37AM Opening Post
I've built an 8 inch f-5.2 dall kirk with a elliptical flat situated around 100mm in front of the primary.
Is a baffle in front of and around the tertiary needed? I have to say I'm not getting the dark background I expected. The final focal ratio is f-19. The secondary is 65mm and the tertiary 45 mm in diameter.
The scope is an experimental design I am replacing the primary with a pyrex mirror I'm working on and the secondary with a smaller 60 convex plano lens from opto sigma. Tests on this from behind the lens with a ronchi show an excellant edge.
Overall the dall kirk gives a lovely flat sharp field with such a long primary.
Posted 04/23/2009 11:02AM #1
There is no reason for Nasmyth not to require baffling. The flat acts as an opening letting light reach the focuser and focal plane just the same. Both, baffle in front of it and around secondary are still needed.
Vla
