Bonding plywood panels
Started by jimmoscheck, 02/16/2007 04:35PM
Posted 02/16/2007 04:35PM Opening Post
Starting on the rocker and need to bond some plywood panels. The book says to jack your car up and place them under a tire. Well, that's not going to happen in February in Michigan. :S
Are there any alternatives anyone could suggest?
Posted 02/16/2007 04:49PM | Edited 02/16/2007 04:51PM #1
I don't know what your budget is, or how large the panels, but hydrolic presses can be had for 200-300 dollars at some tool outlets here localy (Harbor freight). Not sure if you have that sort of store in your area. Hydrolic presses are usually good for a minimum of 10 tons, way more than you probably need. The presses I have used have had deck widths of anywhere from 18 to 24 inches, so if that gives you any idea on the size of piece you could fit.
It is what it is...
Posted 02/16/2007 05:01PM #2
I now have a good selection of clamps but in the past I have used concrete blocks/bricks or a box of books to put weight on some panels. In a real pinch, go to Home Depot and purchase a couple of bags of play sand. They could be returned for a refund when you're done with them but that's not my style.
have fun,
dan
Posted 02/17/2007 12:12AM #3
I think this thread is over-emphasizing the need for pressure to bond panels. I do this a lot, since I belive in rigid rocker boxes. Depending on overall dimensions, I either use mutliple clamps, or place an unused piece of similar size over the glued panels, and put some barbel weights on it. Jacking your car up to compress with a tire is not only overkill, it will probably put so much stress on the bond that the panel will warp when you take it out.
SCollett's attachment for post 111662
Posted 02/20/2007 04:51PM #4
I used 25Lb free weights from a barbell set. I think 25 to 50 lbs is plenty. The sand is a cheap alternative.
Good Luck Dave
Posted 02/20/2007 05:23PM #5
Well, it looks like the sandbags did a fine job.
I got worried after reading Dave B.'s post concerning Titebond III needing 175 lbs. sq/in. pressure. shocked I guess it helps that my panels were very flat to begin with and I had a flat surface to work on. I sandwiched the panels between some extra pieces of plywood and even though I didn't have nearly enough weight as recommended the panels look real good. Thanks for all the help! grin
Hopefully I'll have the rocker together by this weekend.
