Mark Eby
M33 Triangulum Galaxy
Cell for 7" mirror - dazed and confused.....
Started by tonykourlas, 11/29/2003 01:33AM
Posted 11/29/2003 01:33AM Opening Post
I'll soon be taking delivery of a 7" diameter (1" thick, 40" focal length) Mark Harry mirror which I plan to mount in a home-made highly-portable telescope similar to Tom Noe's excellent Teleport design.
I've yet to design the mirror cell and thought I would do a search on this forum for inspiration. What I found has left me a wee bit confused... here's what I picked up.
- mirror clips to keep mirror in place introduce diffraction as well as pinching which distorts the image
- diffucult to keep mirror in optical center with sling approach... scope goes out of collimation. I'd imagine this effect is more pronounced with a small lightweight mirror like mine. The safety catches used to keep mirror from falling out if scope is pointed below horizon will also cause diffraction.
- Silicon blobs grip the mirror and cause optical distortion in cold climates (egad... I live in Ottawa, Canada)
HELP! Have I got this wrong? Are there other options? What's the best option for a mirror like mine?
I've got a rendez-vous with the southern hemisphere skies early next year and need to get cracking if the scope is to be completed in time!
Thanks in advance for your help,
Tony Kourlas.
Posted 11/29/2003 03:46AM #1
Tony,
Don't do the sling. In fact, Tom himself is dumping the sling in the next batch of Teleports. I have a 7" f/6.7 Mark harry mirror, also 1" thick. You can hardly go wrong in this case, but push-pull cells aren't hard. I used Nylon spacer/sleeves on long 1/4"x20 bolts. The bolts extend through the rear ring of the push-pull cell to be "pulled". My lower posts are 120 degrees apart because the push pull cell was a replacement of a built-in sling cell. I'd have gone 90 degrees if I could have, or better yet gone with a rocker bar on each side and a 4-point lower support. However, with the 7" mirror that is 1" thick, I really don't think it matters much.
Mike
mhosea's attachment for post 73599
