Chop Saw Blade
Started by stuper1, 05/14/2007 07:27PM
Posted 05/14/2007 07:27PM Opening Post
A friend loaned me a chop saw to use for cutting aluminum tubing. It has a 6" aluminum oxide cutting wheel. From what little I've been able to pick up on the internet, I'm getting the impression that that wheel is not the best thing to use for cutting aluminum tubing. Can anyone tell me what kind of a wheel/blade I should buy? Thanks
Posted 05/14/2007 09:03PM #1
I was told to use a regular wood blade and aluminum would cut just like wood. I don't know if this is true as I didn't trust it. Maybe someone here can confirm it.
I used a pipe cutter- it only took most of the evening to get my poles cut to length. :S
Posted 05/14/2007 11:55PM #2
Reversing the blade and using WD-40, turpentine or kerosene as a lubricant gives good results.
Posted 05/18/2007 02:41PM #3
A wood crosscut blade will work fine if you can't find a dedicated blade. The oxide blade will work, but it isn't the best thing to use.
You really need to use some kind of "lubricant" to keep the soft aluminum from clogging up the teeth -- probably why people also reverse the blade. You can use candle wax, we use a "tallow" product that works really well. Just letting the blade cut the the lubricant for a second or two every other cut or so should be good enough.
Good luck,
Steve C.
