Clam Shell Modification
Started by Barry Simon, 12/04/2004 05:16PM
Posted 12/04/2004 05:16PM Opening Post
On numerous occasions I have modified the arc of a finder bracket by working the base on an appropriate diameter tube that had appropriate grit "stick on sandpaper". This has been a very labor intensive process by hand. Of course dependent upon how much modification was needed. Usually this has taken hours.
I have a TeleVue clamshell, the one sold for the TV 85, TV 76, and the Pronto, that I would like to modify for use with a Unitron 3". This would entail taking about 1/8" of aluminum off of the radius. Can anyone propose how this could be done other than by slowly opening up the diameter by working the two halves on an appropriate sized pipe with sandpaper? I don't have a lathe, but is there a way to set up a lathe to do this work?
Barry Simon
Posted 12/04/2004 07:27PM #1
You could likely set it up in a 4 jaw chuck in a lathe. Otherwise if you were to built a wooden jig to hold the bracket and make a circle guide for a router, by taking small steps down of about .050" per pass ...you could remover the material in about 15-30 minutes...
Regards,
Preston
