Iris Nebula
Clutch Material for a GEM Polar Axis Drive
Started by TheDesertSage, 09/09/2006 08:09PM
Posted 09/09/2006 08:09PM Opening Post
Hi -
I recently acquired an old Schaefer mount in need of some TLC. This mount has the mass of the drive gear on the FRONT end of the polar axis, making for a very stable scope platform. A disk of teflon is used between the RA drive gear and the polar housing face. This allows the gear to slip freely as it's driven along. I'm looking for a "clutch disk" to go between the gear and the disk of the Declination housing. Some friction is needed at this interface for keeping the scope moving with the RA gear. I've heard of cork and other resilient materials being used for drive gear clutches, but I think that would need frequent replacement. Any other ideas out there? Thanks! - Chuck
Posted 09/09/2006 08:27PM #1
I've used automotive gasket cork which is about 1/16" thick for a couple of similar applications and it has worked well. The important part is getting decent quality stuff that doesn't compress much and doesn't crumble like bulletin board type cork would.
Joplin
Posted 09/10/2006 02:53AM #2
In his older mounts Schaefer used sheet brass for a clutch. There were occasional problems because cutting the brass sometimes warped it. He later switched to linen phenolic for the clutch. He also switched from teflon to HDP for the thrust bearing because of teflon's tendency to cold flow under pressure causing problems with the worm alignment. I've had good luck with canvas phenolic which is much cheaper than linen phenolic. Whichever you use be sure to scuff it up with 100 grit sandpaper on both sides.
