curved vanes ??
Started by moutinho, 07/02/2004 01:32AM
Posted 07/02/2004 01:32AM Opening Post
what is the difference between the straight and curved spider vanes ?
How can I improve my 12.5" f/4.7 for planetary observation ?
Andre
Posted 07/02/2004 11:37AM | Edited 07/02/2004 11:38AM #1
The topic of curved vanes seems to be covered. As to how to improve your telescope for planetary performance there are a few other things you may wish to consider.
I am a big fan of flocking paper and have had good success using it in my 12.5 f/6. So I would suggest flocking wherever you can. This includes the inside of the mirror box, the inside of the secondary cage, inside the tube of your focuser and inside the barrel of your EPs (if they are not premium EP). I have done this and it provided a noticable improvement in contrast, particularly at lower power. It also recuced the amount of scattered light when viewing planets at high power.
Collimate often and precisely. After I acquired and learned how to use the Tectron tools, I sold my laser and I have never been disappointed. Although my scope is set up at our club's observatory, I collimate before every session and sometimes after a couple hours of observing.
If you observe where there are ambient light sources, you may wish to consider adding a light sheild (flocked) to extend out from the secondary cage.
Determine if your primary has a turned edge (much more common than people admit). You can determine this with a Ronchi EP ( http://schmidling.netfirms.com/ez-testr.htm ). Masking off a turned edge will improve planetary contrast significantly.
Although these modifications will improve planetary performance, you'll also see a difference in deep sky performance.
The one thing specific to planetary performance I have been able to do is to install fans to cool the primary mirror. This has increased the upper end of my high magnification by about 50%.
In short, there is a lot of puttering one can do to provide significant improvements without changing the optical elements. It's worth it to some people but not for all.
Gary Weber
