diagonal size on a F/3.6 mirror
Started by devilred, 04/21/2006 05:15PM
Posted 04/21/2006 05:15PM Opening Post
hi
i have inherited a 8" mirror from my dad.
the stats are the following:
focal distance f:=58.6/2 = 29.3 inch
F/# = 29.3/8 = 3.66
Surface Accuracy : 1/4 wave
Full Coating: al+sio
Scratch-Dig: 60/40
Chamfer: 1x45'
Mirror thickness: 0.75 inches = 19mm
i was looking arround in my basement, and found a 10", 8ft long SONOTUBE
so i have the oppurtunity to build my first scope.
but i have many many many questions
1. i calculated the minor axix for the diagonal mirror to be 2.5", which takes 9% sourface obstruction and 30%diameter. is this too much?
2. i am thinking of buying a primary mirror cell like this one:
http://www.meridiantelescopes.com/detprim.htm#mirrorcell
i was wondering if anyone knows how to attach that to a SONOTUBE
3.i want to have a 2" focuser, but i dont know the difference between a 2" and a 1.25" eyepiece. speaking of which, i would like to know what should my first eye piece be? i just want to see if the whole assembly works, and it will be used for planets and nebulas at the beginning.
4.is it worth building a dobsonian mount, or i will be better off buying an equatorial ?
5. given that i have no experience with any of this, is it a wise choice to build this thing, or should i invest the money in buyng one instead.
thank you for any help you can provide.. advice, i what i am looking for!
Posted 04/21/2006 07:06PM #1
>>>hi
F/# = 29.3/8 = 3.66
Scratch-Dig: 60/40
Chamfer: 1x45'
Before you get too involved in this project, I am curious about the source of the mirror. The specifications are very similar to many of the mirrors sold on Ebay and in general, these often are spherical rather than parabolic and in general do not result in a satisfactory telescope.
Also, an F3.66 mirror has a very small diffraction limited region, coma and eyepiece astigmatism are quite significant and normally people with scope F4 or under definitely use a Paracorr.
My concern here is that you may invest a fair of amount of effort and money into this project only to be disappointed by the results. I am not trying to dissuade you from building the scope but rather want to make sure that you understand what you are getting involved in.
Posted 04/21/2006 11:26PM #2
I was going to suggest it might be a Cassegrain primary whose secondary has been lost -- but your mirror is pretty thin for that. Still, it could be an ATM. (I happen to have collected a couple sets with around f/3.6 primary...)
I think it doesn't hurt to give it a try. Could make a very nice RFT!
-- William
