RICHARD COFER
Dob Alt Bearings
Started by matt7591, 03/22/2004 05:05PM
Posted 03/22/2004 05:05PM Opening Post
Hi, got first light with my 10" Dob this weekend. It was the first clear night in several (seemingly a long time). Truly serendipitous. Now the but...
The scope was beautifully balanced and smooth in motion until I added the finder! I plan on using both a finder and a Telrad, so the additional weight of the telrad will really tip the scale.
Is this something I can fix with a material of different friction? I used those teflon furntiture slider disks you find at Home Depot. Or do I have to try to get it closer to pivot point (more invasive).
Matt
Posted 03/22/2004 09:06PM #1
BTW, the motion is great from zenith until about 45 degrees. After that, it will continue down.
I'm hoping that adding a couple more of the disks will add enough surface area to increase the friction, although the additional surface area will decrease the PSI so I don't know if that will be the solution. Wish I was more of an engineer type.
Matt
Posted 03/23/2004 12:07AM #2
Wouldn't it be better just to use some nice-looking weights and balance the tube? Scopestuff sells them for just that purpose.
S.S.
S. Sherrod
Posted 03/23/2004 07:07PM #3
Some other alternatives to adding weights, since you said the balance is pretty close, could be:
-move the finder further down the optical tube toward the center of gravity. (no rule says it has to be at the top)
-use a detachable container (box, tupperware, screw-on-the-cooler-lid-water-jug-thingy) for the bottom counterweight that can be filled with local material (water, sand, rocks, etc.)once you arrive at your destination.
-virtual counterbalance using springs and pulleys.
